So here I was driving down the road...
Old Feb 15, 2008 | 05:22 AM
  #21
drperry's Avatar
Default RE: So here I was driving down the road...
Is it bad when you can see your crank shaft?
[IMG]local://upfiles/5070/A2CE27A069E74CD399C946D0669C71A7.jpg[/IMG]
[IMG]local://upfiles/5070/0DA350362C5349A3881C53761E7FDB47.jpg[/IMG]
[IMG]local://upfiles/5070/2600B9A9AB284E099F8EEF3F4F0B652E.jpg[/IMG]
[IMG]local://upfiles/5070/7DC335A02EFF475B914E251DC8BDC8CB.jpg[/IMG]
Old Feb 15, 2008 | 05:26 AM
  #22
TheBrettster's Avatar
TheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond repute
THERE SHOW BLOWS
*Combining Consecutive Posts*
ORIGINAL: drperry
Look at the boof mark on the crank AND I DONT CARE ABOUT MY DOUBLE POST.
*EDIT by swartlkk* - Use the EDIT feature.
Old Feb 15, 2008 | 07:24 AM
  #23
ORIGINAL: drperry
Old Feb 15, 2008 | 07:38 AM
  #24
drperry's Avatar
That's just a love tap...
Old Feb 15, 2008 | 07:48 AM
  #25
That's purdy! Must have lost a rod. Are you sure it didn't make any noises before it died on ya?? How loud did you have the music cranked?
Old Feb 15, 2008 | 08:51 AM
  #26
drperry's Avatar
At about 20 out of 35.... You can still hear cars and trucks passing you
So yeah, shopping time, lol.
Old Feb 15, 2008 | 09:04 AM
  #27
WolfPack's Avatar
Wow..so..what part exactly is missing? For the non-engine-part literate..that's the lower engine, blew off the oil pan and a bit more? The crankshaft sits at the bottom of the V right?
Pardon my ignorance
Old Feb 15, 2008 | 09:07 AM
  #28
TripleBlackBlazer's Avatar
The oil pan is actually a structural part of the engine on the newer engines, don't know when it started. Meaning there's no separate oil pan that you can drop with a gasket in between. Looks like the actual casing cracked and fell off.
Old Feb 15, 2008 | 09:08 AM
  #29
WolfPack's Avatar
Ah ok..yea I can definitely see the cracked/broken edges on the left and right of the pic.
Old Feb 15, 2008 | 09:13 AM
  #30
The oil pan is still replaceable even though it is a 'structural' part of the engine. The change happened between '97 & '98 when they moved from the stamped steel pan to the cast aluminum pan. The aluminum pan is sealed with an o-ring as opposed to the old gasket that could be over compressed.
From the looks of it, something came loose in the rotating assembly (#1 or #2 cylinder rod would be my guess) and smashed the pan good. No other reason for that to happen really...
