spare tire carrier?????????
Old Aug 14, 2009 | 09:04 PM
bigred77's Avatar
bigred77 is on a distinguished road
Question spare tire carrier?????????
what does it take to get a spare tire carrier like what you see on zr2's to work on a regular 4dr blazer???????? is it a matter of drilling a couple holes and mounting it or is it more technical then that???????? if possible to do this were could the tire carrier be found to buy???????
HELP
Old Aug 14, 2009 | 09:10 PM
kiwiblazer's Avatar
You should be in New Zealand. Our 4 door Blazers come stock with & without the spare hanging on the back like your 2 doors.
Old Aug 15, 2009 | 12:21 AM
warthogdriver's Avatar
i am thinking of going this route...need to work out details
http://www.rangerovers.net/outfittin.../rearbump.html
check out the Kaymar Rear Bumper and Tire Carrier
portion of the page.
Old Aug 15, 2009 | 01:18 AM
CodFos's Avatar
CodFos is an unknown quantity at this point
I'm pretty sure there is more then drilling two holes, try searching for it. I remember seeing something a while ago when I considered doing it as well. It might just be a couple steel weights to disperse the weight of the carrier.
Old Aug 15, 2009 | 11:05 PM
The_Beast's Avatar
The_Beast is on a distinguished road
Well since I have a tire carrier I guess I can give a little bit more information
I recently took off the tire carrier and strike plate to repaint them and behind them, guess what, steel anchors, they look to be about 1/4" thick (kinda hard to tell). It's definitely not going to be easy to weld them one b/c it's going to be hard to get behind the panels. Another thing to consider is the cost of everything, the bolts the hold the tire carrier are about $8 each.
Good luck, if you still decide to do it make sure to post pictures
Old Aug 19, 2009 | 12:40 PM
bigred77's Avatar
decided not to do it
Old Aug 19, 2009 | 02:17 PM
Sisk's Avatar
It's definitely more work then just drilling holes. The support mounts for the spare tire carrier on the 2dr's weren't built into the 4dr's (to my knowledge anyway). The spare tire carrier is in no way light either, so extra support would definitely need to be built in before attaching the carrier.
Old Aug 20, 2009 | 10:33 AM
buck8907's Avatar
buck8907 is on a distinguished road
Would my 2wd ls have the structural braces to put a carrier on it? I have the mini spare thats takin up valuable room..
Old Aug 20, 2009 | 04:47 PM
The_Beast's Avatar
^^ I kinda doubt it but you never know (a dealership should)
junkmonkey
Apr 8, 2007 05:41 AM
Jimmy29067
Jan 7, 2007 02:54 PM
RacerX_96
Apr 4, 2006 01:14 AM
Ricks Blaze
Jan 29, 2006 06:54 PM
buckwheat
May 20, 2005 04:04 PM
