Speed Limiter/ Governor
Old Jun 12, 2007 | 05:21 PM
Default RE: Speed Limiter/ Governor
Good luck with that...
Old Jun 12, 2007 | 05:22 PM
BLK85's Avatar
BLK85 is an unknown quantity at this point
ORIGINAL: Luca1Blazer
I do some long highway trips and it would be nice to be able to hang with the faster cars that typically seem cruise at about 100-110 mph.
If you want to cruise at that speed for an extended period I would make sure to get a better tire. Aren't the factory tires a R rating or something?
Old Jun 12, 2007 | 05:43 PM
R rated (106 mph) hence the 98mph speed limiter. With light truck tires, you have a very good tendancy to not be running them at their recommended load levels and pressures. A few PSI over or under and/or excess load and your probability of tread separation increase dramatically.
Old Jun 12, 2007 | 07:10 PM
scotty_btm's Avatar
scotty_btm is an unknown quantity at this point
Yeah, i like to drive fast too, but not in my blazer. i've only taken it to 95. When you get new tires, the installers generally set the limiter to about the safest maximum speed for your set of tires, assuming perfect balancing and tire pressure. Like said before, a little one way or another on tire pressure and balancing can really put your tires in a bad situation. if i were you, i'd stick with the blazer's limit and take a car when you want to keep up.
Old Jun 13, 2007 | 04:20 AM
drperry's Avatar
Most installers don't touch the speed limiter at all... They don't even adjust your speedometer if you put different sized tires on...
Old Jun 13, 2007 | 09:48 AM
Luca1Blazer's Avatar
Luca1Blazer is an unknown quantity at this point
Points well taken, I won't betampering with the speed limiter. Thanks.
fitrider150
Feb 3, 2010 09:56 AM
blazer3
Engine & Internal
Jun 23, 2006 01:26 AM
2klt
Feb 20, 2006 02:29 PM
pilgrim
Jan 13, 2006 11:52 PM
2001Blazer4x4
Apr 20, 2005 12:09 AM
