stalling 03 blazer
Old Apr 11, 2016 | 06:47 PM
saul88's Avatar
saul88 is on a distinguished road
Default stalling 03 blazer
Hey everyone! I'm new to the blazer forum. I have an 03 blazer 4.3L with 162k and I tried recently to go on a little road trip vaca with the wife but once we hit the freeway and got up to 60 on a hill the blazer started bogging down and we had to pull over to a gas station. When i tried to give it gas it bogged down and stalled out. I just replaced the spider injector and now I smell gas and instead of stalling out when I give it gas it does the opposite. Sounds like there is a clanking sound now that I haven't heard before?
Old Apr 11, 2016 | 08:09 PM
Welcome to the forum.
Here's the first step in locating the problem: https://blazerforum.com/forum/2nd-ge...eakdown-88305/ Post all 4 readings, and we can help analyze them.
Old Apr 19, 2016 | 04:06 PM
saul88's Avatar
1) Confirm fuel pump activation. (If the pump runs when the ignition is initially turned to the RUN position, or bypassing the relay, move on to step 2.) At the fuel pump module electrical connector: The gray wire must show battery voltage when the fuel pump relay is activated. The black ground wire must show less than 5 ohms resistance to chassis ground. Checking these may require dropping the fuel tank to gain access to the connector on the fuel pump module.
2) Make sure the fuel filter is not clogged or restricted.
3) Check for and repair any kinks, restrictions, or external fuel leaks in the 3/8” fuel pressure line, and the 5/16” fuel return line between the fuel pump module and the connections at the fuel metering block.
4) Connect the fuel pressure tester to the service port in the 3/8” steel fuel pressure line located at the rear of the plenum, near the distributor. Activate the fuel pump and check for leaks at the service port connection, repair if/as necessary. Here’s a link to an adequate fuel pressure tester: https://actron.com/content/fuel-pressure-tester-kit it’s not “professional grade” test equipment, but for occasional DIY use, it should be fine.
Old Apr 19, 2016 | 04:10 PM
saul88's Avatar
Thank you for your quick reply. Sorry I took so long to repost. You know how life gets. So I don't know what to do first. Where should I start? Were those post I just posted the ones you wanted?
Old Apr 19, 2016 | 05:11 PM
checklst's Avatar
checklst is on a distinguished road
No 2 would be the first and easy fix. Do you hear the fuel pump making noise? If not I would always suspect the TPS Throttle position censer followed by MASS air flow censer both will starve a fuel injector.
Old Apr 19, 2016 | 05:48 PM
saul88's Avatar
What's a no 2? Yeah I turned the key and heard the pump. Then I smelt gas when I turned it over
Old Apr 19, 2016 | 05:51 PM
The 4 things that you posted, are quoted from the link that I included in post #2. I wrote the article to help members diagnose the fuel delivery system on their vehicle. Post the 4 readings that you took on your vehicle, and post them here so we can analyze them.
Old Apr 19, 2016 | 06:37 PM
saul88's Avatar
I don't have any readings that I took. When I bought the vehicle the guy had a code reader. I don't remember exactly what it was. Are those the reading your talking about?
Old Apr 19, 2016 | 08:31 PM
No. Click on this link, and follow the instructions: https://blazerforum.com/forum/2nd-ge...eakdown-88305/ Then post all 4 pressure readings.
skoot61
Jul 21, 2008 07:29 PM
pkallis
Jun 23, 2008 11:07 AM
ralph10
Mar 23, 2007 01:21 PM
dragonsdeath
Oct 7, 2006 01:08 AM
Urenemy
Jul 7, 2006 02:40 PM
