Temp. gauge not rising. No heat blowing
Old Dec 26, 2022 | 10:19 PM
bowmantyler's Avatar
bowmantyler is on a distinguished road
Default Temp. gauge not rising. No heat blowing
The heat stopped in my 2000 Blazer and the temp. gauge only raises slightly after being warmed up. What's going on here? How can I fix my heat?
Old Dec 27, 2022 | 06:18 AM
rockp2's Avatar
I generally first suspect a stuck open thermostat and/or low coolant.
Old Dec 27, 2022 | 01:39 PM
If the coolant temp was looking correct, then the likely culprit would a plugged heater core or a broken blend-door actuator. But, since you also have apparently low coolant temps, then you likely have bad thermostat, as rockp2 suggested.
Old Dec 27, 2022 | 06:26 PM
AJBert's Avatar
Xeleventybillion
Mikeman84
Feb 26, 2018 09:53 AM
rexmburns
25
Jan 28, 2013 01:56 PM
Blazer Guy
Mar 30, 2011 07:11 PM
Tinted
30
Feb 15, 2011 12:40 PM
tckocher
Jan 15, 2009 08:12 AM
