thermostate & overheating
Old Oct 3, 2010 | 12:28 PM
blushiho's Avatar
blushiho is on a distinguished road
Default thermostate & overheating
I have a 95 blazer, 4x4. When put I put in a new fan clutch, water pump,themostat; the temp went to 260 degrees. Without the thermostat it is 110 degrees. Tried 2 other brand new themos, same thing. Replace temp sender, no change! With cardbd in front of rad, no higher than 110. What could be the prob? Any help or ideas, I would be so appreciative!!!!!
Old Oct 3, 2010 | 02:43 PM
01vortec's Avatar
01vortec is an unknown quantity at this point
sounds like faulty thermostats. throw em in a pot of boiling water and make sure theyre opening.
Old Oct 3, 2010 | 04:06 PM
blushiho's Avatar
did that allready i shut the car off for 2 minutes the temp drops then goes right back up in a minute .
Old Oct 17, 2010 | 08:36 AM
xanmanz31's Avatar
xanmanz31 is on a distinguished road
I am also having this issue no matter what thermo I try truck overheats quickly
Old Oct 17, 2010 | 02:03 PM
01vortec's Avatar
faulty water pump? clogged radiator/hoses, when the truck is running are the radiator hoses stiff, or squishy? hot or cold? do you have heat in the vehicle?
Old Oct 19, 2010 | 04:42 AM
xmradioguy's Avatar
xmradioguy is an unknown quantity at this point
does your bottom rad hose have a spring in it so it can't collapse?
JohnBarJB
Sep 28, 2020 07:34 PM
usmc0311
Mar 13, 2011 09:12 PM
rminier
Apr 17, 2010 02:40 AM
NOs
Jan 22, 2010 12:47 PM
RCarp48
Apr 2, 2007 07:19 PM
