Trailer wiring kit
Old Dec 26, 2008 | 11:52 AM
fondo's Avatar
fondo has a little shameless behavior in the past
Default Trailer wiring kit
I was wondering where I might find a trailer wiring kit for my 1993 olds bravada. Is it possible to find one for this year or will I have to do something else? Also is there a kit that eliminates any cutting or splicing something that is as easy as plug in and go. Thanks
Old Dec 26, 2008 | 09:08 PM
Byte Stryke's Avatar
Byte Stryke is an unknown quantity at this point
Default RE: Trailer wiring kit
as far as I know if you purchase a kit for a 93 blazer S-10/15 it will fit.
you can try places like Autozoned or a truck parts place (Camper shell shops)
they are pretty cut and dry clip ins and come with instructions usually.
Im no Electrician and Ive installed a few without any fires.
Old Dec 28, 2008 | 07:00 PM
neo71665's Avatar
I got mine from bumper to bumper auto parts. Was like $18 if I remember right.
Old Jan 5, 2009 | 12:17 AM
fondo's Avatar
ORIGINAL: fondo
I was gonna install a kit that I bought from a local trailer store and was surprised to find that I had a flat 4 plug wire harness partially installed all ready. I found it when I removed the spare tire and jack from the rear driver side inner quarter panel and started shuffling some of the tail light wires around. The kit I bought has a black box with a 12v feed wire that runs directly off of the battery along with all the other necessary wires coming out of it. I believe this is an isolator box. Is it recommended that I use this instead of the simple harness that is already in use (partially). I would like to stick with this simple set up and get my $45 back from the trailer store (even though it says on the receipt: "NO REFUNDS ON ELECTRICAL PARTS"). The harness has not been routed outside of the truck for some reason and I'm not exactly sure which way I want it to go. Any Ideas? I was thinking about cutting the flat 4 connector block off and then running the feed wires under the rear most of the carpet and then down and out through one of the two existing holes that are used for the tailgate electrical and the license plate light pigtail. Then I would crimp the wires back together and run the ground wire to a nearby ground cable screw. Either one of the holes has a rubber grommet that I will have to run the wires through or on the outside of. Think that will work?
phxjosh
Oct 30, 2013 10:03 AM
krosebud84
May 11, 2007 04:54 PM
The Franchise
May 31, 2006 12:28 AM
Rups63
Apr 7, 2006 11:14 AM
trapper_canada
Aug 15, 2005 11:33 PM
