Transmission shop recommendation? Near Van. B.C.
Can someone please recommend any transmission shops that they've had good experience with? In the greater Vancouver (Burnaby/New Westminster?) area of B.C. What I'm hoping for, is a shop that will not tell me I need a rebuild, IF there are other, lower cost options (yeah I know.....good freakin' luck). Thanks
What is the Transmission doing thats cause for it to be looked into?
A few days ago, it started slipping (equally?) in all forward gears, and no/very-little reverse. But only when cold.
180,000 miles. Fluid is not really bad (half pink, half brown, but not dark). Filter has not been changed in 7 years. Put in a large cooler 7 years ago (by-passes in cold weather). Have on done a 2 partial fluid changes since then (3.5 L). |
Stick to the point of the thread. There already is a discussion thread on his symptoms which could have been found with only a few clicks if one were to have looked.
Try Pacific driveline in North Burnaby. 604-298-1978 ask for John.
Brad |
Avoid blackwell transmission
Avoid blackwell trans in surrey. Try Pat's driveline they are awsome
Thanks.
Called Pacific Driveline. John said $3,000 ballpark.
Suggested buying a new truck instead; as mine is 180,000 miles. I'm dying. |
Zr2 jimmy iv seen for cheap
Zr2 jimmy with low km might be worth checking out
Ita on fb market place for sale in nanaimo this forum wont let me past the text Its 146000km for 2800 zr2 package |
Thanks.
| All times are GMT -5. The time now is 06:51 PM. |
