Trip and Towing
Old Mar 14, 2011 | 04:31 AM
nktidwel's Avatar
nktidwel is on a distinguished road
Question
I was supposed to leave Saturday, but thats another story. Anyway, when I can actually go, I have a question. First off, I have a 1990 Full Size,350tbi, 700r4, 4x4, 3.08, running factory size 31 10.5 15 tires, reese class 3 hitch. I will hopefully be pulling a uhaul auto transport, empty weight 2,210lbs, carrying a 1984 AMC Eagle Sedan about, with an empty gas tank ~3100lbs. The trip is ~640 miles, until I can unload the Eagle at my sister's house, and drop off the trailer. Is this setup going to be okay? How about going uphill, and over mountains (and of course back down)? I have towed short distances on flat ground before, but not with the blazer.
If this setup is a bad idea, how about a tow dolly, 750lbs, and dropping the driveshaft on the AMC?
Last edited by rriddle3; Mar 14, 2011 at 06:26 AM. Reason: COMBINING CONSECUTIVE POSTS
Old Mar 14, 2011 | 08:37 AM
AJBert's Avatar
Your suspension can handle that much weight easily. Your brakes will be overworked unless the trailer has hydraulic brakes, so you will want to check on that. If the trailer has electric brakes you will need to install a controller. The tranny will do the job but will get a bit warm. Best thing to do is add an aux tranny cooler. The engine won't have a problem.
This all being said assuming your Blazer is in good mechanical shape with no current problems.
Old Mar 14, 2011 | 10:47 AM
nktidwel's Avatar
The trailer will not have electronic brakes. Some models, however have an emergency brake, activated with a third chain (separate from the safety chains).
Old Mar 14, 2011 | 09:43 PM
4x4blazerguy's Avatar
If the trailer has a break away switch then it has electric brakes. Electric brakes are required by law. If you were to have an incident you could be held at fault if your trailer brakes aren't hooked up or working. To think it through a little further if some was killed you could be held on manslaughter charges.
Old Mar 15, 2011 | 02:31 PM
nktidwel's Avatar
I will be towing on one of these. U-Haul Transport, with an 1984 AMC Eagle on top of it.
Old Mar 18, 2011 | 05:43 PM
AJBert's Avatar
The trailer comes with hydraulic brakes, according to the link you posted. You'll be good to go as far as brakes go.
DaveC
May 16, 2010 09:31 PM
Puffie40
Nov 17, 2009 01:20 PM
ComputerNerdBD
Jun 24, 2009 10:33 PM
greenbean
May 21, 2009 08:49 AM
Fenris
Sep 16, 2008 04:19 PM
