What rearends are in the Blazers?
Old Jan 16, 2007 | 04:11 AM
BLK85's Avatar
BLK85 is an unknown quantity at this point
Default What rearends are in the Blazers?
Just like the title says. I would like to know whats in mine but it would be nice to know whats in other ones.
Old Jan 16, 2007 | 06:50 AM
Chevy Lover's Avatar
Default RE: What rearends are in the Blazers?
Rear Axle Identification
In your glove box you should have a list of RPO codes. Diff codes srart with a G
GT4
Rear Axle: 3.73 Ratio
GT5
Rear Axle: 4.10 Ratio
GU4
Rear Axle: 3.08 Ratio
GU6
Rear Axle: 3.42 Ratio
G67
Level Control: Automatic
G80
Rear Axle: Positraction
Old Jan 16, 2007 | 09:09 AM
BLK85's Avatar
I actually ment what rear end as in 10 bolt, 12 bolt, etc. Im guessing its a 10 bolt but I dont know by looking and havent found it in the owners manual.
Good info though.
Old Jan 16, 2007 | 09:39 AM
drperry's Avatar
10 bolt, and if I remember right, it's a 7 5/8"
Old Jan 16, 2007 | 09:41 AM
tammikm's Avatar
tammikm is an unknown quantity at this point
whats the preferred rear end? besides a nice blonde.. hehe
Old Jan 16, 2007 | 09:45 AM
DetroitMuscle's Avatar
DetroitMuscle is an unknown quantity at this point
Depends what years but I think most 1st gens are using the same rear ends as the f bodies just different supension.
Old Jan 16, 2007 | 09:53 AM
The ZR2 & Highrider suspensions (Chevy & GMC variants) has an 8.5" rear ring gear. All others have the 7-5/8" ring gear. And yes, they are the GM-corp 10 bolt. The G80 locker is GMs Gov-loc arrangement and while it may be perfectly fine for on road to light offroad use, anything more and you'll want to put in a true posi or locker setup depending on your level of offroading.
Old Jan 16, 2007 | 09:58 AM
drperry's Avatar
ORIGINAL: swartlkk
Got any suggestions on a good posi? Locker's are cool and all... but a posi rocks for 2wd slides, lol
Old Jan 16, 2007 | 10:09 AM
ORIGINAL: drperry
ORIGINAL: swartlkk
Auburn makes good posi units, I used to run an air locker in my "strip/street" car, I am looking into the powertrax for the blazer, if you know how to use tools you can install it yourself in under an hour without touching the gears.
Old Jan 16, 2007 | 10:14 AM
It all depends on if you have the G80 locker or not. In an open case, everything can be installed without removing the carrier. If you have the G80, I don't think anything goes into a G80 carrier... So that means you'd need to find an open diff carrier and transfer over your gears, install new bearings, then install the posi/locker unit of your choice.
