What rearends are in the Blazers?
Old Jun 8, 2007 | 03:39 AM
  #21
drperry's Avatar
Default RE: What rearends are in the Blazers?
ORIGINAL: Jigg
Not that hard really... i've got one for sale if you want it
It even has a G80, disc brakes,and 3.42 gears... you'd be all set! Between the 8.5" rear and the iron front diff you have, you'd be pretty well setup for lockers!
Really? I don't have no puny aluminum front diff? that's pretty spanky... that means an elecronic locker is a posibility! lol.
Do we know the size/specs of the front diff? I think I'm going to have to take a look at my diff... Maybe I got lucky and got the 8.5"... Which would be really nice, as Auburn has a limited slip locker for the GM 8.5" 10 bolt rear end...
Though, the fact that you've got one sitting there with 3.42's is pretty swanky too, lol... Shipping would be killer, though...
Time to go take a picture of my diff! lol
Though, I suppose, to confirm the iron front diff, the only way is with a magnet? no special part numbers or anything, right? lol
Edit: Damn... I think I've only got the 7 5/8" diff...
[IMG]local://upfiles/5070/E6A328C1D22146DA9212CF39591B252B.jpg[/IMG]
Old Jun 8, 2007 | 07:48 AM
  #22
Jigg's Avatar
Jigg is an unknown quantity at this point
ORIGINAL: lastcoupe
EDIT......Hey Jigg, is that 8.5" G80 out of a 2-door or a 4-door? If it comes with a manual only, it's have to be a 2-door of course, but aren't they different lengths? IIRC, the 4-door's rear axle housing is a couple inches wider?
It was out of a 2dr. I've never heard that the 4dr's are wider... can anyon confirm that?
Old Jun 8, 2007 | 08:13 AM
  #23
drperry's Avatar
The body might be wider, but I don't think the axles are... Not 100% sure on that, though...
Edit: from what I can find, the track width of the rear on the 4 door does appear to be a little bit larger... by an inch or less...
Only a ZR2 axle is wider, as far as I knew...
Old Jun 8, 2007 | 11:10 AM
  #24
lastcoupe's Avatar
lastcoupe is an unknown quantity at this point
I'm pretty sure the body is the same width, but like I said I think the 4-door's axle is a little wider than the 2-door. I'll do some research on it though. How much you want for the axle Jigg? Where is it located?
Old Jun 10, 2008 | 04:45 PM
  #25
bad350v8s10tahoe's Avatar
bad350v8s10tahoe is an unknown quantity at this point
I run an auburn posi in mine and im lovin it! also 4:10 gears with 33 inch tires are perfect for a daily driver [8D]
Old Jun 10, 2008 | 06:28 PM
  #26
drperry's Avatar
I want the Auburn ECTED... I want LSD locker, lol.
Old Jun 10, 2008 | 11:57 PM
  #27
Blazin_Jason's Avatar
ORIGINAL: bad350v8s10tahoe
Good to hear. My blazer is running 4.11's, stock G80 limited slip, and 33's. With a 350 as well. Just need to finish it.
Old Jun 11, 2008 | 12:14 PM
  #28
Cool! Got pics other than the engine?
Old Jun 11, 2008 | 12:28 PM
  #29
drmrman's Avatar
drmrman is an unknown quantity at this point
GU6 G80! Going to check if its a 8.5 later... but I doubt it...
Old Jun 11, 2008 | 02:46 PM
  #30
95Blzr's Avatar
95Blzr is an unknown quantity at this point
So Do I have a aluminum front diff?
