Where to access fuel pump 1995 S10 blazer
Old Nov 4, 2014 | 08:49 PM
mark from michigan's Avatar
mark from michigan is on a distinguished road
Default Where to access fuel pump 1995 S10 blazer
Does anyone know where to cut an access hole in the floor of a 1995 S10 Blazer for access to the fuel pump?
Old Nov 4, 2014 | 10:03 PM
richphotos's Avatar
Do you plan on doing it again? If not, just drop the tank. If you plan on keeping this for a long time ( I cut an access panel in my 93 jimmy) What I did to find the location to cut, was measure. Nobody will be able to give you specific measurements.
So.. to find where to cut. there is enough room to see the fuel pump if you look between the rear wheels and the wheel arch. Take a tape measure and out it in that area and measure, do the same for the other side, then visually do that with going to the rear of the truck.
Once you have those, Make a 1x1' cut, and the fuel pump should be in the middle.
Its not hard, I did it on my first try.
But honestly. If you do not plan on keeping this until it dies... just drop the tank.
The only reason I did this is because I plan to keep the jimmy until it dies.
ALSO.. Dont be cheap on fuel pumps... Get a delco or delphi....
Old Nov 4, 2014 | 10:07 PM
richphotos's Avatar
Also, since you commented on an older thread. let me link you to that thread which has more than enough info to help you out
https://blazerforum.com/forum/2nd-ge...h-cabin-77109/
Old Nov 5, 2014 | 12:00 PM
thanks, mark
762mm
Mar 28, 2021 01:54 PM
jsgrind
Jul 21, 2014 06:42 AM
comandoed
Mar 13, 2013 06:56 AM
dubaholic2
Jun 19, 2011 09:06 PM
jcortes63
Nov 3, 2008 11:10 PM
