16" spoked alloy wheels OEM
Hello, Trying to find which OEM (Factory)wheels fit my 2004 4dr,4wd Blazer.I am specifically looking for 16" 5 spoke
but any OEM alloy wheel info would be appreciated. 5 lug x 4.75 bolt circle.
I heard that some Firebird and Camaro wheels would fit but I am not sure which years and styles.(Formula Firebird ?
IROC Camaro ? )
My Blazer has 4 wheel disc brakes as I believe all 2004s do.
I am trying to save a few bucks PLUS be able to find a replacement if a wheel ever gets damaged.
I feel aftermarket wheels go out of production so fast that if I ever needed to replace a wheel I may not be able
to find one.
IROC Camaro ? )
to find one.
RE: 16" spoked alloy wheels OEM
The Camaro/Firebird rims should fit on any 4x4 model or so I have read around on the net. I have been looking for a set of these:
[IMG]local://upfiles/667/F1F43E80DC9C45F5B2FAADEFCD7170E3.jpg[/IMG]
Or actually may just buy a set of Blacked out steel rims to entirely black out my truck.
Can't beat these at at $50 each, only problem is the 16x8 rims have a 4-1/2" backspacing which I don't think is correct for our application.
[IMG]local://upfiles/667/BB66C0514C7F44E5A72C3812A31DD806.jpg[/IMG]
Check this site out for wheels that might fit your Blazer. I remember another site claiming that the 4X4's needed a wheel more like a FWD for offset numbers....so the Camaro wheels might only fit certain model 4X2 Blazers????
get some longer studs and a spacer. It'll fit. See?
Genuwine Inner/outer racing tire!
TheStampedOctagon
Tires and Wheels
03-17-2011 02:20 AM
manekDC2_
11-05-2010 03:55 AM
