General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
1991 4WD issues
Old Nov 24, 2006 | 04:26 PM
Real420's Avatar
Real420 is an unknown quantity at this point
Default 1991 4WD issues
I own a 1991 s-10 blazer and my 4wd worked until recently. It will not engage. I tore apart the boot and console to discover that the electronic "doo-hicky" ( a technical term ill have you know) was unattached. So I thought that this may be the problem. So after reattaching the aforementioned doo-hicky the 4wd still is not working. I have also done the electric reset and it still does not work. Any ideas?
Old Nov 25, 2006 | 05:53 AM
Chevy Lover's Avatar
Default RE: 1991 4WD issues
Maybe it's the vacuum whatchamacallit under the hood.
( another informative technical term). for the front axle actuator.
I just wonder if the transfer case is in 4wd but the front axles are not engaging. If you were to put the truck on a hoist or 4 jack stands and (with all the wheels off the ground) see if the front drive shaft is pushing the front diff, but the axles are not turning.......know what I mean?
Miket919
Jan 21, 2012 12:57 PM
pirkeltooned
Jun 10, 2010 11:11 PM
nash_686
Nov 25, 2009 06:43 AM
SniperX13
Apr 29, 2007 12:48 AM
dobbins
May 6, 2006 07:52 PM
