General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
1995 blazer won't start
Old Nov 19, 2006 | 08:18 PM
mjj's Avatar
mjj
mjj is an unknown quantity at this point
Default 1995 blazer won't start
My 1995 blazer won't start it all started last week if I left it set a while it would start right up then if I shut it off if it would take a while to start then the other night it just refused to start I put a little gas down the throttle body it started up finally and ran and idled just fine got it home shut it off then restated it and it started right back up now I can't get it to start at all I think it is the fuel pump it does have 152,000 miles on it. Just thought I would see what you guys think I read it frequently and you guys answer most of my questions without having to ask.
Old Nov 19, 2006 | 09:58 PM
Chevy Lover's Avatar
Default RE: 1995 blazer won't start
The best way to confirm a failed fuel pump si to install a fuel pump pressure tester and do a proper test.
Old Nov 19, 2006 | 11:34 PM
If it runs fine, I would suspect that it is not the pump. More often than not, it is a leak somewhere in the system that bleeds off the pressure. Try turning the key to the run position for at least 15 seconds before attempting to start it. This will allow the fuel pump to pressurize the system.
If that works, then you'll need to find what is bleeding the pressure off. If you have no external leaks, it could be a faulty injector, a failing FPR (fuel pressure regulator) or a faulty check valve in the pump.
fenman00
Nov 13, 2013 11:38 AM
Sky
Feb 12, 2012 10:04 PM
wings4kites
Jul 10, 2010 07:28 PM
Rogue7
Jan 18, 2009 10:31 AM
VikezFan
Nov 17, 2008 09:13 AM
