General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
95 blazer 4x4 problem
Old Mar 5, 2006 | 08:48 PM
reeperrobb's Avatar
reeperrobb is an unknown quantity at this point
Default 95 blazer 4x4 problem
hello I am new this site, and usually the forums are very informational. I just recently aquired a 95 blazer 4x4 and notice that the 4x4 switch won't go into 2h and I grounded the 13th pin to see the switch flashes and it flashed twice paused and again twice might anyone know what this means?
Old Mar 5, 2006 | 10:59 PM
blazin97's Avatar
blazin97 is on a distinguished road
Default RE: 95 blazer 4x4 problem
welcome to the site.
Old Mar 5, 2006 | 11:08 PM
Jman's Avatar
Jman is an unknown quantity at this point
Pull the switch apart to check that its not broken. They break easy. If you know anyone with a simalar Blazer try thier switch. If nothing else, it will eliminate the switch as the problem.
Old Mar 6, 2006 | 03:46 PM
reeperrobb's Avatar
hello thanks for the welcome. I took the switch apart tested and its ok. I checked out a few other posts and wondering if it is the tscm? but that would be a guess.
Old Mar 6, 2006 | 10:43 PM
4lowlife's Avatar
Shift motor and or the TCCM could be shot.
Old Mar 18, 2006 | 01:24 PM
Johnnyboy's Avatar
Johnnyboy is an unknown quantity at this point
I have a 94 Blazer w/an automatic & 233 transfer case. I assume your 95 has an electronic shift 4x4. If so they should be the same. If you get a trouble code 2 when you ground pins J & A then code #2 is an encoder fault. The encoder switch is not servicable. It is located in the Transfer Switch Motor assembly on the transfer case. If the encoder is bad, (it has to fail 25% of the time to store a fault code)you should only be able to shift from 2 wheel high to 4 wheel low. The encoder tells the TCCM what position the transfer case is in. You probably need to replace your electric transfer case motor assembly. They cost around $200.00 unless you go to a dealer who will charge you around $400.00-$500.00. Check ebay Ive seen them for under $200.00. Also make a quick check of your fuses. Believe it or not make sure your 15amp radio, 5ampTCCM, 15amp Turn/Bu & the 30 amp power acc. circuit breaker are good. All those fuses supply power to various systems needed to control the 4x4 electronics.
PS other fault codes for the 4x4 are #1 Ram stanby power lost, #2 encoder fault, #3 TCCM motor circuit & #4 RAM/ROM Failure. Good Luck !! John
T0 clear 4x4 troble codes remove the 5amp TCCM fuse for 2 1/2 mins, then cycle the ignition 5 times to clear codes. I replaced my transfer motor & its working fine now.
tdbone1
15
Nov 30, 2012 06:53 PM
Tinted
35
Feb 7, 2011 01:12 PM
English5
Jul 16, 2010 11:11 AM
razman
Feb 22, 2009 01:57 PM
sfesenko
Nov 30, 2008 08:55 PM
