General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
'96 Blazer accelleration "ping"
Old Aug 14, 2006 | 07:32 PM
trkyhntr's Avatar
trkyhntr is an unknown quantity at this point
Default '96 Blazer accelleration "ping"
new here and have not found much with the search on this problem..
I have an '96 Blazer 4.3L 4X4..under accelleration the engine "pings " (like pre-ignition ?? ) and just doesnt seem to have much/any power to it..
the engine has almost 103k on it..no codes come on the scanner..I've changed plugs and wires,tried different gas..Im thinkin' maybe the MAP sensor ?? But wouldnt that flip the service light on ??
anyone with any ideas for me to try or things to check would be greatly appreciated
Old Aug 15, 2006 | 10:46 AM
lunatic_magnet's Avatar
lunatic_magnet is an unknown quantity at this point
Default RE: '96 Blazer accelleration "ping"
check your timing? (throwing things out there)
Old Aug 15, 2006 | 05:02 PM
1996BZR's Avatar
1996BZR is an unknown quantity at this point
by trying different gas, did you go up to a higher octane?
Old Aug 16, 2006 | 02:03 AM
trkyhntr's Avatar
ORIGINAL: 1996BZR
yep..even tried adding various octane boosters
didnt know the timing could be advanced,the sticker under the hood says that ignition timing and idle speed are automatically controlled and not to attempt adjustment..
Ive been driving "beaters" for 20 years,so this '96 Blazer is my first "high tech" vehicle,so I really dont know much about all this computer controlled stuff. My wife drove it for 3-4 years.Shortly after she got it,it had the intake gasket replaced and really hasnt been the same since even though it was done at a dealer,so maybe the timing does need advanced a little. How do I do that ?
Old Aug 16, 2006 | 10:10 AM
The base timing should not be modified unless it is found to be off. I believe you have to disconnect a wire inside the passenger compartment inorder to check the base timing. Until you check the base timing, I would not move the distributor.
One thing that has been coming up more as of late is wear on the gear on the bottom of the distributor. If this wears enough, the commanded timing may be maxed out and still not be enough to work properly. I can check this with my scan tool, but most code readers cannot.
I would pop off the distributor and check the contacts inside. If anything has deposits on it, replace both the cap and rotor.
Good luck and keep us posted!
Old Aug 16, 2006 | 02:46 PM
trkyhntr's Avatar
Ive changed plugs,plug wires,dis. cap and rotor,air filter.. should add that its worse once the engine is warmed up,on a cold engine it does not do it
Ill have to see if I can figure/find out how to check the base timing...
I guess I need to find a service manual ,anyone know where I can get one ? Im talking about the shop service manual,not a Haynes or Chilton
Old Aug 24, 2006 | 09:14 PM
trkyhntr's Avatar
so far I havent got anywhere on this..thought maybe I had it worked out but today was a "pingin'" day
Old Aug 24, 2006 | 09:31 PM
It is also possible that you have some carbon buildup on the inside of the cylinders that is creating hot spots.
Have you tried running either GM Top Engine clean or Seafoam through the intake?
Old Aug 25, 2006 | 02:44 PM
trkyhntr's Avatar
ORIGINAL: swartlkk
not yet,Ill pick up a can of Seafoam today and run it through over the weekend though
could be carbon,it has almost 103k on it and only pings when the engine gets hot (warmed up)
also swart, I was told the base timing isnt adjustable ?? that doesnt seem right to me,can you or anyone else verify that ??
Lightemup
Jul 13, 2011 12:41 PM
maxell12342003
Dec 21, 2009 04:32 PM
gscrippler
Apr 29, 2008 10:58 PM
ggwash21
Jul 31, 2007 08:36 PM
dogz46
Nov 6, 2006 02:31 PM
