General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
98 Jimmy: Barely Running, popping exhaust, bad sulfer (egg) smell.
Old Jun 30, 2006 | 10:52 AM
apekim's Avatar
apekim is an unknown quantity at this point
Default 98 Jimmy: Barely Running, popping exhaust, bad sulfer (egg) smell.
My 98 Jimmy is barely running. Strong egg smell out the exhaust. The an area of the muffler shell is popping in and out. It can barely move on its own power and surges sometimes. I can hear something in the exhaust before the cat....like there is something clanking in there.
Occasionally, over the past few years the exhaust will gurgle at startup and after you shut it off. Kind of like the sound a roman candle makes when it shoots up one of the flares.
Mike
Old Jun 30, 2006 | 11:09 AM
BoAtlanta's Avatar
BoAtlanta is an unknown quantity at this point
Default RE: 98 Jimmy: Barely Running, popping exhaust, bad sulfer (egg) smell.
easy answer, catalic(mis-spelt need coffee) converter needs to be replaced,one that is clogged will do all you describe.
Old Jun 30, 2006 | 02:57 PM
apekim's Avatar
Have you seen this happen before?
Does the muffler have to be replaced as well? Or does it usually kill that as well?
Thanks,
Mike
Old Jun 30, 2006 | 04:50 PM
DINO55's Avatar
DINO55 is an unknown quantity at this point
ORIGINAL: apekim
Thanks,
Mike
Your Muffler should be fine, unless small chuncks of the cat broke loose and went thru the exuast system. How old is the exhaust system on it? Are you planning to keeping the truck for a while or just short trem? If it was me, I would just replace the entire exhaust system, if I was planning to keep it. Again that's just me....
VeroWing
36
Nov 12, 2013 08:40 PM
phatso_99blaz
Headers, Intake, & Exhaust
Apr 8, 2013 03:16 PM
birdsfan82
Jan 7, 2013 07:04 PM
shrooms
Sep 3, 2012 06:25 PM
scook
Mar 24, 2008 08:16 PM
