Anti-freeze smell in the cabin?
I would recommend a flush and fill with Prestone Extended Life 'All Makes, All Models' antifreeze. Compatible with everything and still the benefits of long life.
Dexcool, in and of itself, is not the problem. It is the fact that dexcool does not wet on the surfaces, coating them to protect. By not wetting, it is a more effective coolant. But also, by not wetting the surface, it allows trapped air to fester. Air which has no business in a cooling system.
ORIGINAL: black19
Great, sounds expensive
ORIGINAL: swartlkk
To keep it simple... The entire removal of your dash!
Its not hard just time consuming to be honest, got a set of tools and mechanical abilities?
