General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
Anti-freeze smell in the cabin?
Old Sep 8, 2006 | 09:11 PM
black19's Avatar
black19 is an unknown quantity at this point
Default Anti-freeze smell in the cabin?
I've noticed lately that when I drive with the windows closed that I can tell the car has a hint of anti freeze smell inside. Anyone know what could be causing this?
Old Sep 8, 2006 | 09:21 PM
DetroitMuscle's Avatar
DetroitMuscle is an unknown quantity at this point
Default RE: Anti-freeze smell in the cabin?
Might be the heater core.
Old Sep 8, 2006 | 09:40 PM
Definitely a leaky heater core. If you have the factory Dexcool coolant and air is allowed to enter the system and remain in the system, you will have problems.
Old Sep 8, 2006 | 09:50 PM
Isnt it better to get rid of the red junk? especially now that the opprtunity is there with a HC change?
Old Sep 8, 2006 | 10:05 PM
I would recommend a flush and fill with Prestone Extended Life 'All Makes, All Models' antifreeze. Compatible with everything and still the benefits of long life.
Dexcool, in and of itself, is not the problem. It is the fact that dexcool does not wet on the surfaces, coating them to protect. By not wetting, it is a more effective coolant. But also, by not wetting the surface, it allows trapped air to fester. Air which has no business in a cooling system.
Old Sep 8, 2006 | 10:12 PM
black19's Avatar
Leaky heater core? What exactly does that entail?
Old Sep 8, 2006 | 10:15 PM
To keep it simple... The entire removal of your dash!
Old Sep 8, 2006 | 10:25 PM
If mine goes out Im not gonna use one. They are a pain.
Would Water Wetter work with the dexcool? It worked great in my street/strip car with aluminam and cast components.
Old Sep 8, 2006 | 10:27 PM
black19's Avatar
ORIGINAL: swartlkk
Great, sounds expensive
Old Sep 8, 2006 | 10:33 PM
ORIGINAL: black19
ORIGINAL: swartlkk
Its not hard just time consuming to be honest, got a set of tools and mechanical abilities?
