General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
belt noise
Old Jul 7, 2006 | 03:02 AM
MsRandi's Avatar
MsRandi is an unknown quantity at this point
Default belt noise
[]just put a full set of new belts on my nissan frontier, and the aircondisener still suuels
Old Jul 7, 2006 | 05:49 AM
Chevy Lover's Avatar
Default RE: belt noise
ORIGINAL: MsRandi
Does the air conditioning work?
Did you try turning the compressor pully with the belt off and if you did, does it turn easily.
Are there any idler pulleys and if there are do they spin with the belt off?
Old Jul 7, 2006 | 09:19 AM
Does it only squeal when the clutch engages? If so, then either you need to adjust the air gap on the clutch, or just replace the clutch. I guess it is also possible that the AC compressor has bitten it as well. If you energize the AC clutch, try to turn the compressor, and find that it is quite difficult to turn, then there is something amiss inside the compressor.
lionel2
Sep 7, 2012 02:45 PM
thecoutures
Apr 13, 2007 01:24 AM
blazerfanatic
Engine & Internal
Aug 27, 2006 09:21 PM
curly2001
Jun 4, 2005 07:42 PM
