belt noise
Old Aug 25, 2006 | 10:47 PM
blazerfanatic's Avatar
blazerfanatic is an unknown quantity at this point
Default belt noise
Hello I have a belt noise that occurs only when the engine is cold or with a/c off. The vehicle is a '97 Blazer 4.3. Any help would be greatly appreciated. Thanks!!!!
Old Aug 25, 2006 | 10:54 PM
Default RE: belt noise
So does it do it when the engine is cold and the a/c is off...? Or will it squeal when the engine is cold and the a/c is on as well?
Old Aug 27, 2006 | 06:17 PM
It is only when it is cold and the a/c is off. It goes away if u turn the a/c on.
Old Aug 27, 2006 | 09:21 PM
K. I couldn't tell from your original description of the problem. Sounds like you have a problem with the clearance on the A/C compressor clutch. This could be caused by rust in the clutch plates. I believe that there is a bolt that holds the compressor drive on the end of the compressor, then the pulley itself is held on with a snap ring (IIRC).
lionel2
Sep 7, 2012 02:45 PM
thecoutures
Apr 13, 2007 01:24 AM
MsRandi
Jul 7, 2006 09:19 AM
curly2001
Jun 4, 2005 07:42 PM
