blazer shut off won't restart
my '94 s-10 blazer started the other morning no problem, then just shut off and won't restart. i replaced the fuel filter, and can hear the fuel pump running, it does turn over fine just won't start. i was gonna try changing plugs and some fuel injection cleaner next. i'd appreciate some sugggestions
my old 96 s-10 did this last fall and i was forced to drive my other car to work, i didnt have time to work on it the first few days but 3-4 days later i got in and cranked it and fired right up, but ran with a studder, i went to a gm dealer and they gave me some fuel injector cleaner and after putting some of that in the lines and when it finally did start and ran itself through it turned out to be the culprit
I've heard many good things about Seafoam. Pour some of the bottle into your intake while running, pour some into your gas tank, and you could put some on your crankcase, but you'd probably have to do an oil change after 100 miles of driving because the seafoam will clean alot of sludge in the crankcase. See my other post on Seafoam. Swartlkk describes in very detail how to use and and all the benefits. Seafoam Post
chester92
Nov 14, 2011 02:50 AM
2dogs2
Mar 27, 2011 07:13 PM
ekerry
Oct 3, 2010 01:27 PM
