General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
Brakes binding?
Old Nov 24, 2006 | 06:33 PM
TammyG's Avatar
TammyG is an unknown quantity at this point
Default Brakes binding?
I have a 95 Bblazer. For about a week it's been lacking power. It's not too bad on level roads at a lower rate of speed, but going uphill or on the highway it just doesn't have what it takes. It's riding smooth, no rough idle...it seems as if something is holding it back. My husband says he smells brakes burning and thinks the brakes may be binding. The smell isn't overpowering. I really don't know, anyone had this problem, any thoughts or suggestions?
Thanks
Old Nov 24, 2006 | 07:02 PM
Default RE: Brakes binding?
You'll really need to get it up in the air and spin the wheels to see if things are binding up. Could be a failing brake line, a seized caliper, or a seized slider pin on the front disk brakes... I believe '95s have rear drums which have less things to go wrong, but if a spring were to break or... Yeah...
If you aren't comfortable with inspecting the brakes yourself, you could always take it to a Midas or equivalent and have them do a free, no-obligation estimate. I would recommend that if you go this route, take it to at least 2 different shops for estimates and compare the repairs listed.
Old Nov 24, 2006 | 09:29 PM
nofear17bmx's Avatar
nofear17bmx is an unknown quantity at this point
Also go to each tire and take a snif of course. Also if they are siezed they are probably getting very hot, so feel the rim to see if its hot.
Old Nov 24, 2006 | 10:04 PM
Chevy Lover's Avatar
I would check for sticking park brake cables. If they don't release all the way the rear brakes will be dragging.
Old Nov 27, 2006 | 11:00 PM
dcup734's Avatar
dcup734 is an unknown quantity at this point
My 98' S10 Blazer has aluminum disk brake calipers which got pitted and locked the pads and had to be replaced. Unfortunately, I couldn't find aftermarket replacements and had to buy OEMs from Chevy.
catmech
May 15, 2010 05:00 PM
Kevets
Oct 28, 2009 05:40 PM
dalifts
Feb 17, 2009 11:12 AM
v7guy
Mar 4, 2008 12:18 PM
ivannj
Nov 22, 2005 04:39 PM
