A/C gauges
Would like to know if it is a fact that AC gauges that were used for R12 can not be used for a system that uses R134...
Can the gaues still be used if the reason they can't be used is due to contamination, but the lines are changed out?
thanks...
thanks...
With the understanding taht the fiting are of different style and size, is there any parts outlet that sell a conversion fitting lit or the like? I have two different manifolds but only one with hoses and they are the old R12 style/size twist on, not quick release...
thanks for any leads...
Yeah, I completely forgot about our adapters... I do believe that we purchased our adapters from Advanced Auto... I would think that about all autoparts stores would carry them... But maybe not anymore...
Our set is like the second one down:
http://www.mytoolstore.com/cps/hoseconv.html
yep that set will get ya hooked right up, and I wouldn't worry about contamination, refrigerant actually boils at about 22 deg. below zero F...so as soon as you unhook them it will basically evaporate out of the gauges and hoses.
Well I appreciate the time and effort to post this, but for almost ninety bucks, NAPA has a new complete setup, manifold, hoses, the whole enchalada... I was thinking for about 20 or 40 bucks, a setup that would adapt the old manifoldover to use when needed. Since I don't do fleet maintenance any longer, no need to spend that much for just a conversion setup....
Thanks again...
Thanks again...
Spectreblazer
Jan 22, 2010 08:59 PM
JasonG
Dec 12, 2005 02:19 PM
