General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
A/C gauges
Old Nov 18, 2006 | 08:24 PM
2klt's Avatar
2klt is an unknown quantity at this point
Default A/C gauges
Would like to know if it is a fact that AC gauges that were used for R12 can not be used for a system that uses R134...
Can the gaues still be used if the reason they can't be used is due to contamination, but the lines are changed out?
thanks...
Old Nov 18, 2006 | 09:01 PM
Default RE: A/C gauges
We still use my dad's old R12 gauge set on all of our trucks/tractors that have been converted over to R134a. I've even used them to check the pressures on my own vehicles.
Old Nov 18, 2006 | 10:45 PM
2klt's Avatar
With the understanding taht the fiting are of different style and size, is there any parts outlet that sell a conversion fitting lit or the like? I have two different manifolds but only one with hoses and they are the old R12 style/size twist on, not quick release...
thanks for any leads...
Old Nov 18, 2006 | 11:27 PM
Yeah, I completely forgot about our adapters... I do believe that we purchased our adapters from Advanced Auto... I would think that about all autoparts stores would carry them... But maybe not anymore...
Our set is like the second one down:
http://www.mytoolstore.com/cps/hoseconv.html
Old Nov 19, 2006 | 01:21 AM
lastcoupe's Avatar
lastcoupe is an unknown quantity at this point
yep that set will get ya hooked right up, and I wouldn't worry about contamination, refrigerant actually boils at about 22 deg. below zero F...so as soon as you unhook them it will basically evaporate out of the gauges and hoses.
Old Nov 19, 2006 | 11:24 PM
2klt's Avatar
Well I appreciate the time and effort to post this, but for almost ninety bucks, NAPA has a new complete setup, manifold, hoses, the whole enchalada... I was thinking for about 20 or 40 bucks, a setup that would adapt the old manifoldover to use when needed. Since I don't do fleet maintenance any longer, no need to spend that much for just a conversion setup....
Thanks again...
Old Nov 19, 2006 | 11:46 PM
I know that my dad didn't spend more than $25 on the kit he has, but I do not know where he got it from. I'd rather get a new setup too though... Just giving you other options.
Spectreblazer
Jan 22, 2010 08:59 PM
Blazer_Xtreme
Jul 30, 2006 03:54 AM
JasonG
Dec 12, 2005 02:19 PM
AW90
Aug 15, 2005 10:32 PM
01xtreme
Feb 19, 2005 05:43 AM
