General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
Changin the starter on a 94 vortec
Old Oct 25, 2006 | 07:57 PM
LTCMidniteRyder's Avatar
LTCMidniteRyder is an unknown quantity at this point
Default Changin the starter on a 94 vortec
Well the starter has went out on my 94 s-10 4*4 (4.3) and now i need to repace it...problem is that ive had several different ways to do it given to me, none which seem to be very attractive. Any ideas on the best way to change the starter out? Thanx
Old Oct 25, 2006 | 08:56 PM
93s15jimmy's Avatar
93s15jimmy is an unknown quantity at this point
Default RE: Changin the starter on a 94 vortec
getting a starter out isn't usually hard to do. i would lift up the front of the truck and put it on jackstands and take it out that way.
Old Oct 25, 2006 | 09:56 PM
Chevy Lover's Avatar
Disconnect the battery. Raise the truck, put it on jack stands. Take the battery cable and the ignition wire off the starter solenoid. Remove the outer mounting bolt, loosen the inner mounting bolt and remove the shim (if there is one) and remove the inner mounting bolt. Slide the starter out of the bell housing and tip it down to remove it. Reverse this procedure to install the new one.
Old Oct 26, 2006 | 01:01 AM
irocknrol2's Avatar
irocknrol2 is an unknown quantity at this point
Its a bit tricky to get the starter down once its loose, you just have to turn it the right way and it falls out. Its pretty tight but managable. Mine was super easy once I took the exhaust loose.
jdmmario
Oct 25, 2014 06:25 PM
rodeofan5656
Aug 14, 2012 08:10 PM
bertrenolds
Apr 27, 2011 07:24 PM
Crap Blazer
14
Sep 21, 2009 12:46 AM
96blkblazer
Feb 26, 2009 04:29 PM
