check engine light_ oil pressure gauge
I just recently did an oil change and today while driving to work my check engine light came on. I'm not sure why, but my oil pressure gauge remained high. I did check the oil level by the dipstick and it was fine. If anyone has any suggestions or ideas as to why my check engine light came on and my oil pressue is high please repond
Your check engine light coming on just after doing an oil change is probably just a coincidence. You should go to Auto Zone or to another parts store that will do a free diagnostic scan for you and get your truck checked out. It will only give you a baseline code, but it's a place to start. Your check engine light can come on for any number of reasons.
I took my blazer to autozone and had them check the code, it came up as P0440- evap emission control system malfunction. The guy could not offer any suggestions, go figure. Does any one have any ideas as to where I may start to diagnose the problem or how it could be corrected, thanks for any replies.
I replaced my gas cap about 6 -8 months ago. I filled up in the morning and checked the gasket , it was fine, I also checked to make sure it was tight which it was. I may look into a new one though, thanks
You can use some carb cleaner. Just take your time and be careful. Don't try to rush it. Auto Zone can also test your EGR valve to let you know if it's any good. I had a problem with mine, so I took it off and cleaned it. My truck was okay for a while then it started acting up again. I took it off and took it to the parts store. They told me that it was shot, so I bought a new one. Can't remember what it cost.
Hey, weird senario, I have not had the time to look at the EGR valve, but today I was going down a very bumpy road and I suddenly got a whiff a strong sulfur smell coming from my blazer. Shortly after that my check engine light turned off and the vehicle immediately started to run smoother. Any other suggestions or comments? Thanks
Sounds like an EGR valve problem. Remove it and give it a good cleaning then let us know if it helps. I don't know about the sulfur smell. It might be something, or it could have been something outside and have nothing to do with your Blazer. Not sure.
