General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
Convert rad fan
Old Jun 5, 2006 | 12:27 AM
c4gibson's Avatar
c4gibson is an unknown quantity at this point
Default Convert rad fan
I know this has been asked before but I haven't been able to find out, What electric fan setup would be the best and easiest to use to replace the clutch fan in my 02 4.3 2wd blazer?
Old Jun 5, 2006 | 10:19 AM
Dory's Avatar
Retired Super Moderator
Dory is a jewel in the roughDory is a jewel in the roughDory is a jewel in the rough
Default RE: Convert rad fan
Just curious why you want to take out the clutch fan for an electric one? I for one would RATHER a clutch fan, you KNOW that it will never not turn on. I had a Trans Am (1988) that had an electric fan and I cant even tell you how many times I had to fight with the sensors, replace them for aftermarket to make sure they turned on and then finally a freaking fan switch that I controlled when that sucker turned on. It would never turn on in time and caused such problems. I would think with a clutch fan at least you KNOW its on, peace of mind I say. lol
Old Jun 6, 2006 | 01:43 AM
c4gibson's Avatar
You are correct in that the fan will almost always be there when required but I really don't like the loud noise it creates. I am willing to put up with the dangers for the reduced noise factor.
I did some more checking and found enough info to get started with a Taurus fan assembly!
Old Jun 6, 2006 | 02:11 AM
cherryred4x4's Avatar
cherryred4x4 is an unknown quantity at this point
As you have found, the 3.8L Taurus V6 E-fan is plentiful in junkyard and cheap, also fits the Blazer's radiator well.
Beware that the E-fans can draw a lot of amps when first switching on. You shouldnt have to worry about this unless you have a lot of high-draw electrical items in your car (ex:amps, off-road lights)
Here's a link to a How-to for the E-fan conversion ..... E-Fan How-To - Click
gitch93
Jul 23, 2013 08:06 AM
Love to be Blazin85
Sep 7, 2008 01:44 AM
1blkblazer422
Aug 28, 2008 10:02 PM
Sharsky7
Jun 22, 2008 02:24 PM
mdemers2006
13
Dec 5, 2007 08:11 PM
