General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
DS side marker lamp replacement
Old May 17, 2006 | 07:17 PM
greengoose89's Avatar
greengoose89 is an unknown quantity at this point
Default DS side marker lamp replacement
OK - you guys were a HUGE help with my last issue. I'm hoping someone has a helpful suggestion to my minor issue. my 98 has the driver's side side turnsignal marker bulb out. I managed to get it out of the socket holder but can't get the bulb out to replace due to the cramped confines. Do you have to remove the entire sealed beam headlight assembly to replace this, or does someone have a quick and easy cheat that wouldn't involve reaiming the headlight after i am done. Hope someone can help because that fast clicking turn signal is driving me nuts every time i turn left!!! Thanks in advance!!!
Old May 18, 2006 | 02:01 AM
20Blazer00's Avatar
Default RE: DS side marker lamp replacement
Lift the hood and look at the grille assy. It should pull right out with out having to remove the headlights. You may have to pull hard and even to get it to come out, do not jerk on it or the grille may either crack or break * IT IS PLASTIC *.
Then you can remove the marker light assy.
HcHawks09
Aug 10, 2011 10:49 AM
nyzr21019
Aug 3, 2009 08:54 AM
Blazerx85
Jul 27, 2007 06:56 AM
