General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
electric 4x4 wont engage loud clunck
Old Nov 10, 2006 | 08:59 PM
Chevy Lover's Avatar
Default RE: electric 4x4 wont engage loud clunck
I don't have a picture, so from what I read, I would think it would be coming from the wiring harness., or you could leave it plugged in and back probe it.
I just looked at the pic in the previous post, it looks like the male end.
Old Nov 10, 2006 | 09:50 PM
benz blazer's Avatar
benz blazer is an unknown quantity at this point
I got 0 ohms on two of the ports. But there is a total of 8 ports on the plug. do you what color wire I need to see the resistance on?
Old Nov 11, 2006 | 02:44 AM
slammins15's Avatar
slammins15 is an unknown quantity at this point
x
Old Nov 11, 2006 | 07:16 AM
I don't know for sure. but from what I understand in the diagnostics chart is that if the groun signal is good, replace the encoder motor. I believe that's where you are now.
The wire for the signal circuit should be black.
I would also think that you would have 0 ohms on 2 of the wires because you have a signal ground and a motor ground, so it sounds like the wiring is ok.
Just make sure that the ATC fuse and the CTSY fuses are both good before you replace the encoder motor.
I've included a diagram of the wiring from the TCCM to the Encoder motor
[IMG]local://upfiles/2910/A60614F9B2D944BB92E3C08430338F46.gif[/IMG]
Old Nov 11, 2006 | 12:16 PM
Everything seems fine to the encoder motor. looks like in going to the junk yards today to find an encoder motor. Ill post if it works or not. Thanks for the help guys.
Old Nov 13, 2006 | 08:27 PM
thaasjr's Avatar
thaasjr is an unknown quantity at this point
I have the same problem. Out of the 8 ports how do you know which ones are the ones you need volts out of? i got volts out of 4 ports and none out of the rest. I was reading 7.3v out of all 4 but my meter may be messed up. Anyway, Should I only be getting volts out of 4 of the 8 probles and if this isn't correct what is my problem? Is it the tccm. I have been messing with this for weeks and want to get it finally figured out. When I do the grounding test my 4wd lights flash a sequence of 2 and then 3. I would think this is my encoder motor but want to be sure before I tear it out and buy a new one.
thanks
toyblazervt
Nov 28, 2010 05:07 PM
OH_VDUB
Dec 21, 2008 02:37 PM
punx.inc
Dec 25, 2007 12:07 AM
180_nissan
Dec 15, 2007 08:06 PM
NitrousJunkie
Sep 12, 2006 10:51 PM
