General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
Electrical Issue?
Old Nov 1, 2006 | 02:23 AM
Bauer318's Avatar
Bauer318 is an unknown quantity at this point
Default Electrical Issue?
I just put a battery in my 98 blazer 4x4, 4 door, 4.3l vortec. I hadn't run it in about 7 months and it started up right away and all fine. I noticed that I heard what seemed to be the right blinker noise. I couldn't get rid of it. Also, every once in a while it just plain wouldn't start up and I would have to mess with the battery wiring and then it worked. I think that could be do to corrosion or something but the first problem has me stumped. Any ideas?
Old Nov 1, 2006 | 02:43 AM
USMaverick101's Avatar
USMaverick101 is an unknown quantity at this point
Default RE: Electrical Issue?
Is the blinker noise coming from the actual blinker? If it is, check the bulb, or even the turn signal fuse.
It could be a bulb. If it is a constant noise, then i'd check the wiring to that blinker.
For the starting, could defintly be loose terminals. Any acid build up could cause a bad connection. If it is an origianl AC Delco batter, they are known to have faulty terminal connections.
Old Nov 1, 2006 | 04:06 AM
Chevy Lover's Avatar
Put some baking soda on the corrosion and rinse it well with warm water to remove the corrosion. If you have a lot of corrosion you may need to use a wire brush. Clean, tight connections are very important.
Take care of your battery connections first, then see if you still have a "blinker noise"
JoSHN
Sep 14, 2012 04:56 PM
zipper_018
May 20, 2007 12:45 AM
regisvu
Sep 19, 2006 12:15 PM
jdpilot
Oct 24, 2005 04:01 PM
Painkiller1990
Sep 17, 2005 02:34 PM
