frint diff
ORIGINAL: blazinnewengland
front diff lock cable works, yet front dif doesnt lock in. '89 S10 blazer two door 4.3
Can you hear the actuator "click" when the cable is pulled by the vacuum diaphram under the battery?
well, i ended up replacing the cable because it was rusted and stuck. yet when i went to engage the front axle manually, all i heard was a slight clunking noise. is that a splined collar that locks the axle? is there anyway i can get rid of the foolish set up. its not a daily driver, though i do drive it to the trails. the whole thing really seems pointles.
I believe Hanr3 has a post with pictures for installing a direct cable to the actuator to engage the front diff.
Check some of the posts referring to diffs or trannys over the last couple of days. If you find it, great, if not I'm sure you could just ask him, or I could search for it.
old skool luvr
Nov 10, 2009 09:20 PM
slayer6x6
Dec 8, 2005 02:24 PM
