General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
front differential problem
Old Mar 24, 2006 | 02:21 PM
dion21379's Avatar
dion21379 is an unknown quantity at this point
Default front differential problem
Hi,
I have a 1998 s10 Blazer with 4 wheel drive. Recently when I am driving, mainly up and down large hills or on a rough road, it sounds like it's trying to go into 4 wheel drive. It sounds like a siren going off, when slowing down it gets louder. If I put it in 4 wheel drive it clunks in then put it back in 2 wheel drive and it's back to normal. When changing the oil the other day I noticed that the front differential housing (carrier) is a connected to a tubular bar going across the truck from side to side, and the section of the differential housing that is connected to that bar (it appears to have some kind of rubber bushing there also) is completely broken away from the housing. I guess this is just to support the differential and allow it to move up and down slightly. I am pretty sure this is the cause of my problem, does any one have any other ideas about what it could be if that isn't it. Also how difficult is it to remove that differential housing to replace it?
Thanks,
Dion
Old Mar 24, 2006 | 02:29 PM
Default RE: front differential problem
If you have access to a digital camera, please take some pictures of the area you are describing.
I'll try to pull up an exploded view of your front end after work today if I can.
Old Mar 24, 2006 | 02:33 PM
dion21379's Avatar
OK, thanks a lot. I will get some pictures put up as soon as possible. It might be a couple days though.
Thanks again,
Dion
Old Mar 24, 2006 | 03:17 PM
dion21379's Avatar
Just an added bit of information, the part that is broken is seen when looking at the differential from the drivers side.
Dion
Drew4711
Oct 6, 2012 12:47 PM
aw99blazer
Aug 19, 2009 10:26 PM
kmalysa
Aug 17, 2009 08:43 PM
SanfordBlazer
Mar 2, 2009 06:37 PM
98BlazerLT4x4
Mar 4, 2008 06:00 PM
