General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
Fuel Pump
Old Oct 16, 2006 | 09:21 AM
blazer_maniac's Avatar
blazer_maniac is an unknown quantity at this point
Default Fuel Pump
Well I just bought my first Blazer, a `98, and after owning it for 2 days I started having start-up problems. I traced the problem to the fuel pump...so I swapped it out yesterday. The new one actually died on me after running for 4 minutes which makes me think that the old one might have been ok. Prior to having problems with the old one, I filled it up with some QT 87 octane. I also remember feeling a stumble leaving QT. Anyhow back to the new pump - I beat on the bottom of the tank and it cranked over and ran for a very short time. I reseated the electrical connector and it fired right over and I haven't had a problem since. Another thing is that I couldn't get the new pump retaining ring on with the new or even the old gasket so I went without it which was not the right move as I have set a code for tank pressure.
Any thoughts or comments in regards to the fuel causing problems as I had, and also the retaining ring problem? I tend to think that since the fuel was common to both pumps that it could have been the problem.
Old Oct 16, 2006 | 04:16 PM
blazinloud's Avatar
Default RE: Fuel Pump
may be a dumb question but did you replace the fuel filter too? could be clogged
also how much did you pay for ur pump? A brand new ac delco pump with labour cost me $1200 cad.
Old Oct 16, 2006 | 09:58 PM
The fuel filter was fine. I paid 300.00 for it from Autozone. It has a 1 year warranty. They had a Bosch for 400.00 with LLT warranty.
BouncingRadical
14
Nov 27, 2015 12:30 AM
cide
Nov 7, 2009 01:26 PM
upblazer95
Mar 8, 2009 07:15 PM
Lckyctch
Dec 30, 2007 05:38 PM
mytruck2
Dec 13, 2006 04:50 PM
