General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
help fuse keeps blowing
Old Jul 10, 2006 | 11:01 PM
live4camaros's Avatar
live4camaros is an unknown quantity at this point
Default help fuse keeps blowing
my 89 s10 blazer won't start i replaced the fuel pump and filter but everytime i go to turn the engine over the fuse blows any help would be greatly appreciated
Old Jul 10, 2006 | 11:24 PM
hillbillyinOhio's Avatar
Default RE: help fuse keeps blowing
which fuse exactly is blowing, mileage, any more info on truck would be helpful
Old Jul 10, 2006 | 11:25 PM
Jman's Avatar
Jman is an unknown quantity at this point
If the fuse keeps blowing, then check the wiring. It is shorting out somewhere. Is it the proper fuse? might want to check that. HTH
Old Jul 10, 2006 | 11:27 PM
it's the ignition fuse i guess it blew about a week ago and i replaced it the blazer started fine today i was driving and the truck died i checked the same fuse as before and it was blown every time i put a new fuse in it as soon as i go to turn the engine over it blows immediatly
Old Jul 10, 2006 | 11:28 PM
where would i start to look for the problem
Old Jul 10, 2006 | 11:31 PM
Jman's Avatar
Find the wire from fuse box to coil or relay and check for cuts or breaks, or bad connections. Not sure what color it will be or how the wiring works on your truck.
Old Jul 10, 2006 | 11:35 PM
thanks i'm just about to pull my hair out i think i'll go over it tomorrow can't see to well now. my dad was sure it was the fuel pump so i spent all afternoon replacing that.
THANKS to everyone for the help i'll let you know if i find the problem
Old Jul 11, 2006 | 02:41 AM
Hanr3's Avatar
It could be your ignition switch. Check the wiring coming off the starter. The single small wire on teh starter comes from teh ignition switch. Disconnect it and see if you blow the fuse. If so then the problem lies in the switch or that wire. If not then the problem might lie in your starter.
Now had you said you were blowing the fuel pump fuse I would have told you to check the oil pressure wiring. The oil pressure is part of the fuel pump circuit.
Old Jul 11, 2006 | 02:44 AM
Hanr3's Avatar
A trick to help find a short.
Use a regular headlight bulb. Remove the fuse, run one prong of hte headlight to one side of the fuse, and the other prong of the headlight to the other side of the fuse. Now when you turn the key, the head light will come on to indicate the short, wiggle the wires around until the headlight goes off. When the light goes off, you found the wires you need to insapect further. A short can be as small as a crack in the wire that makes contact with the frame. Saw that little trick on 4x4 trucks this past weekend.
Old Jul 12, 2006 | 01:15 PM
thanks for the help guys I'm going on a hunt this afternoon haven't been able to even look at it but thanks again i'll let you know what i find
thanks again,
Ta'Lina
