General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
help, I can not detach the dash of my 95 blazer
Old Aug 12, 2006 | 10:16 PM
wxj1974's Avatar
wxj1974 is an unknown quantity at this point
Default help, I can not detach the dash of my 95 blazer
I try to change the heater core of my 95 ls blazer. Finally, I found I can not detach the dash. How many bolts fasten the dash? where they are? Help! My truck is mess now, Thank you
Old Aug 12, 2006 | 11:32 PM
lastcoupe's Avatar
lastcoupe is an unknown quantity at this point
Default RE: help, I can not detach the dash of my 95 blazer
These are the absolute easiest dash to remove in any car! I can have one on the floor in under 10 minutes litterally (my boss timed me because he didn't believe me either[sm=shades.gif]). Anyway now that I'm done bragging.....lol....I'll try to help ya. I'll assume that you have the hush panels (all 3) on the bottom of the dash out as well as the lower left side dash extension and the IP trim plate. You should have the radio, cluster and heater controls out as well. Take the windshield air deflector for the defrost off by gently prying up to release the clips. this will expose a few 7mm bollts, remove them. next take out the two IP speaker grilles (2 screws in each) and remove the 7mm bolts under the grilles (1 on each). Disconnect the two large wiring harness connectors under the right side of the dash. Remove the two bolts (either 13mm of 15mm) that support the steering column and lower it down to the driver's seat. Take out the two 10mm bolts at the lower left and right corners of the dash and roll the top of the dash forward. Be carefull and make sure you disconnect the harness connectors at the base of the winshield area in front of the steering wheel ( either 1 or 2 connectors ...can't remember). The entire dash harness stays on the dash when you remove it except the radio antenna coaxial cable. You have to feed it through the dash after you roll it forward. You should be ready to remove the entire IP at this point, just be carefull around the steering column and make sure you disconnected all of the harness connectors. I may have forgotten a few small details (It's been a while since I did a 95-97 model) but that's the just of it.[sm=feedback.gif]
Oh yea, welcome to the site!
Old Aug 13, 2006 | 12:15 AM
wxj1974's Avatar
Thank you, I have 4 bolts emoved under the dash and the dash is stand still. Shall I remove all the bolts I can see? Or there still sth except the bolts under the speakers and defroster? Thank you so much.
Old Aug 13, 2006 | 01:06 AM
1996BZR's Avatar
1996BZR is an unknown quantity at this point
In ten minutes? Wow, I thought it would be hard to do. I'll just hire you if I need the heater core changed
Old Aug 13, 2006 | 12:58 PM
lastcoupe's Avatar
The only bolts that physically hold the dash in are the ones under the grilles, the defrost deflector and the lower outside corners of the dash.
Yes I know it's hard to believe, even some of the technicians that start where I work doubt me but I have proved it on several occations. One time I removed mine just to win a bet that I couldn't do it in under 20 minutes, that time it took me 12minutes and 14 seconds. When my boss timed me though, I had it on the floor in exactly 9 min. 52 seconds. And yes I would be glad to do heater cores for ANYONE on this site for $150.00 labor. And I'll even get you my discount on G.M. parts (10% over dealer cost).
Old Aug 13, 2006 | 10:43 PM
wxj1974's Avatar
Thank you very much, I have done the job today. It's really a hard work when you do it first time.
Old Aug 14, 2006 | 02:12 AM
1996BZR's Avatar
When I need my dash taken apart, how about a step by step process of how to do it? Or maybe I'll just pay you to do it.
Old Aug 14, 2006 | 08:44 PM
lastcoupe's Avatar
No problem, I'll be glad to help either way.
TEALBlazer
May 12, 2011 06:12 AM
f1yrod
Apr 17, 2008 03:20 PM
f1yrod
Apr 17, 2008 06:39 AM
Canadian_Blazer
Feb 23, 2005 03:19 AM
