HELP Right front end noise
Have a right front end mech noise front the front end at about 35 mph and above. Noise is there in 2wd and 4wd. All 4 wheels of the ground the noise sounds as if it is in output shaft tube. I replace right cv shaft, right wheel bearing, had it at dealer and they replaced carrier bearing. I still have the noise. Anyone have a clue as to what the noise might be?
Thanks James
Thanks James
RE: HELP Right front end noise
Im bumping this back to the top for anyone who hasn't seen it. im not sure what the noise is but i dont want it to get lost.
typically the wheel bearing or cv shaft are the culprits, but you replaced both of them. Not sure why the dealer would replace the carrier bearing, when your complaining of the noise up front.
Can you provide a better description of the noise it is making?
Are you getting any shakes or shimmys, or vibrations?
Does applying the brakes make any difference?
Does truning make any difference?
joeyscar
07-02-2012 12:12 AM
YAXTA'S04BLAZA
02-26-2011 02:08 PM
Chrismacster
04-02-2009 06:57 PM
redpeppers
04-07-2007 04:55 AM
