General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
hesitating then surging now SES light
Old Apr 23, 2006 | 03:38 AM
93blazerman's Avatar
93blazerman is an unknown quantity at this point
Default hesitating then surging now SES light
About a month ago my blazer started hesitating, I cleaned out the egr valve and replaced air filter and fuel filter. It ran ok for a couple of days then it started surging. The hesitating and surging only happened between 40-50 mph and when it was warm. Today I took it for a drive and the SES light came on and it was idling really bad. I have a 1993 s10 blazer with 158 k miles. It has the vortec v6. Any help would be appreciated.
Old May 5, 2006 | 12:24 AM
mandi's Avatar
mandi is an unknown quantity at this point
Default RE: hesitating then surging now SES light
Do you notice the light comming on more often in certain conditions? Like highway driving or stop and go driving?
Old May 5, 2006 | 12:45 AM
4lowlife's Avatar
Clean the MAF w/ electric parts cleaner. Check the plug spark plug wires fro chaffing, cracks...
Old May 5, 2006 | 03:36 PM
It doesn't seem to do it in the morning or before it warms up. Once warmed up it will hesitate on take off and surge while cruising above 40 mph. Once I get to 50 mph it seems to go away. If I drive it for more than 5 minutes the SES light comes on. I pulled out the EGR and it was stuck halfways but I cleaned it again and same problem. I checked all spark plug wires but did not check spark plugs. I did notice what seemed to be a crack in the hose from pcv to throttle body and I repaired that but still no fix. Have not cleaned MAF yet I will give that a try and replace the spark plugs. Should I use AC delco Rapid fires or just Standard ac delco plugs?
jewag87
Jul 20, 2014 05:05 PM
Chic_Bowdrie
18
May 12, 2013 09:21 PM
mxzretta
Apr 23, 2012 09:04 PM
Coldspot
Jan 14, 2008 06:05 AM
ggwash21
Jul 31, 2007 08:36 PM
