SES Light... Okay now what??
Old Jan 13, 2008 | 01:27 PM
Coldspot's Avatar
Coldspot is an unknown quantity at this point
Default SES Light... Okay now what??
Had the service engine soon light on, went to Auto Zone and got a coolant below thermostat temp code. Advice from here was try the thermostat. Did that today, and now temp is reading about four ticks higher on the temp gauge (just below the 210) and I noticed that the blazer is shifting better and less oftenwhen accelerating. I disconnected the battery for about 40 minutes (had lunch) but the SES light is still on? Does it need to be phyically reset some how? A battery disconnect didn't seem to do anything. Any help would be appreciated.
Thanks
Old Jan 13, 2008 | 08:19 PM
HeyYou's Avatar
HeyYou is an unknown quantity at this point
Default RE: SES Light... Okay now what??
You may need to replace the temp sensor for the ECM as well. Disconnecting the battery for 40 minutes should have done the trick.... If you have access to a scan tool, that will show data, see what the ECM thinks engine temp is....
Old Jan 13, 2008 | 09:23 PM
I would try to have the codes cleared by a scan tool first. It is possible that the ECT is bad though...
Old Jan 13, 2008 | 10:00 PM
Coldspot's Avatar
Where would a guy find this ECT to replace it if that what was needed. I have a 2002 Blazer.
Thanks
Old Jan 13, 2008 | 10:44 PM
rriddle3's Avatar
I've circled it in the illustration.
[IMG]local://upfiles/4800/38D0C159D2CE436EBDF7E0685686954A.gif[/IMG]
Remove the air cleaner inlet tube assembly anddrain the coolant to below the level of the sensor. When you install the new one, be sure to coat the threads (only) with GMP/N12346004 sealer or equivalent and tighten to 15 lb ft.
Old Jan 14, 2008 | 06:05 AM
Search would have yeilded the same results as riddle posted...
jewag87
Jul 20, 2014 05:05 PM
calee4nyaboy
Nov 20, 2009 11:48 PM
gstrat323
Tires and Wheels
Apr 22, 2008 08:35 PM
2001BlazrLS
Detailing
14
Mar 28, 2008 08:29 PM
93blazerman
May 5, 2006 03:36 PM
