General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
hesitation at highway speeds...
Old Sep 15, 2006 | 04:14 AM
Chevy Lover's Avatar
Default RE: hesitation at highway speeds...
To test the TPS use a voltmeter (analog is better that digital for this) check for voltage (key on-engine off) between the black(ground) wire and the grey (signal) wire.
use pins to penetrate the wires so you can leave the connector on the TPS
As you operate the throttle the voltage should climb from .5v to 5.0v steadily
Operate the throttle very slowly, the needle on the volt meter should climb steady with no little bumps or drops
tazz9690
91
Nov 21, 2020 05:04 PM
RIFLEMAN 308
Mar 3, 2010 08:07 PM
Wanted
Nov 12, 2007 08:14 PM
Scoody Boo
Jan 17, 2007 03:14 PM
black19
Aug 8, 2006 02:26 AM
