Interior Door Panel Fasteners - 1997 Blazer S-10
Does anyone know the correct GM and aftermarket PART #'S for the correct factory replacement door panel fasteners that holds the interior door panels in place to the steel door? They attach to the interior door panel and then the ****** end snaps into the actual interior steel door. I have motorized windows and door locks. Seems that DormanProducts has several selections, but not sure which ones would be the correct ones for the direct factory replacement.
ORIGINAL: sleonh
I think that what you are looking for is GM PN 15963179 - trim panel retainer
Should be under $0.50 each from your local dealer. I would call them up first to verify the PN though.
i just took one of the good ones into autozone and bought a box of fasteners that looked similar. they work fine. if you'd like i can try to find the box and get the part number for you.
edit:
found the box. dorman gm panel retainers, #799-130. you might have to twist them around a bit to get them to fit, but they worked fine on my '97.
edit:
zenxavier
Jun 30, 2014 07:46 PM
jaq62
15
Jun 24, 2011 01:24 PM
