General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
Interior Door Panel Fasteners - 1997 Blazer S-10
Old Jul 2, 2006 | 08:51 PM
sleonh's Avatar
sleonh is an unknown quantity at this point
Default Interior Door Panel Fasteners - 1997 Blazer S-10
Does anyone know the correct GM and aftermarket PART #'S for the correct factory replacement door panel fasteners that holds the interior door panels in place to the steel door? They attach to the interior door panel and then the ****** end snaps into the actual interior steel door. I have motorized windows and door locks. Seems that DormanProducts has several selections, but not sure which ones would be the correct ones for the direct factory replacement.
Old Jul 2, 2006 | 09:16 PM
Chevy Lover's Avatar
Default RE: Interior Door Panel Fasteners - 1997 Blazer S-10
ORIGINAL: sleonh
I don't have a part #, but what I do is take an original out of the door and just match it up.
Old Jul 2, 2006 | 10:02 PM
I think that what you are looking for is GM PN 15963179 - trim panel retainer
Should be under $0.50 each from your local dealer. I would call them up first to verify the PN though.
Old Jul 2, 2006 | 11:49 PM
magtec's Avatar
magtec is an unknown quantity at this point
i just took one of the good ones into autozone and bought a box of fasteners that looked similar. they work fine. if you'd like i can try to find the box and get the part number for you.
edit:
found the box. dorman gm panel retainers, #799-130. you might have to twist them around a bit to get them to fit, but they worked fine on my '97.
zenxavier
Jun 30, 2014 07:46 PM
jaq62
15
Jun 24, 2011 01:24 PM
02xblazer
Jan 5, 2010 01:58 PM
rkilgore
Jun 30, 2008 09:42 PM
chevfan2000
Jul 17, 2006 11:12 AM
