General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
intermittent engine light
Old Nov 18, 2006 | 12:17 AM
marks89's Avatar
marks89 is an unknown quantity at this point
Default intermittent engine light
ok, i have a 89 full size blazer w/a 350 TBI. at engine speeds at or over 50 mph my light comes on. when i check the codes it comes up 32 and 42. its relates to the map sensor and module not getting a signal. it doesn't idle on its own w/o pressing on the gas when its cold. thing is it runs great. tows 6-7 k fine. i've replaced the egr and solenoid but still having problems. any ideas or common problems with this engine like this? TIA!
mark
Old Nov 18, 2006 | 12:52 AM
Chevy Lover's Avatar
Default RE: intermittent engine light
I believe a common problem is for the throttle body base gasket to blow out. It's a cheap fix to replace the base gasket and it only takes about 1/2 hour.
Old Nov 18, 2006 | 06:27 PM
marks89's Avatar
OK, Thanks i'll give it a try!
Old Nov 19, 2006 | 11:07 AM
Blasir's Avatar
Banned
Blasir is an unknown quantity at this point
An easy way to check your throttle body base gasket is to spray carb cleaner at the base and see if it is sucking it in. I changed mine on an 88 that I had. Hardest part is being very careful with fuel inlet lines. Otherwise was a snap.
Old Nov 19, 2006 | 05:52 PM
marks89's Avatar
should i do a TBI spacer too? do those actually work?
n.kognitoh
Sep 13, 2010 11:50 PM
DaveC
Apr 6, 2010 07:33 PM
shade tree
Oct 26, 2009 07:45 AM
oktain
Apr 29, 2009 11:42 AM
filtalr
Nov 24, 2007 12:07 AM
