General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
intermittent power windows?
Old Nov 9, 2006 | 11:11 AM
45auto's Avatar
45auto is an unknown quantity at this point
Default intermittent power windows?
hey guys, i need the wizardly help of the blazer forum once again. ('96 blazer 4 door) driver's power window went out last year, put in a new motor, worked fine. recently stopped working again. drivers rear door window also has failed now. funny thing though, when it's cool to cold outside they do function. but who wants to take the chance of it getting stuck down! any thoughts of wisdom greatly appreciated & everybody have good weekend.
Old Nov 9, 2006 | 12:43 PM
DCFluX's Avatar
DCFluX is an unknown quantity at this point
Default RE: intermittent power windows?
If you punch the window controls and it starts working it is either a oxidized contact or a bad ground. Seen this crap on alot of Dodge products.
Old Nov 9, 2006 | 08:28 PM
rooster's Avatar
rooster is an unknown quantity at this point
the drivers controls act as a master control that the other switches relay off of. i had a similar prob on my pass door changed the pain in the *** spring loaded motor and still didnt work, so i changed the drivers controls and wahlah problem solved, quessed i could have saved a few bucks by coming here first. also could just be a loose or worn control switch, my new one is know acting as a child safety, so i have to push up slightly on the corresponding switch to allow others to use their windows.
Old Nov 19, 2006 | 09:21 PM
45auto's Avatar
maybe the controls? they work fine when it's cold outside, when it's warm sometimes not. gotta be a contact issue.
Old Nov 19, 2006 | 10:11 PM
Chevy Lover's Avatar
It's gotta be a poor connection somewhere. A wire to a connector or a connector to a switch, or a connection at the motor itself.
Dmorse87
Mar 15, 2011 10:30 PM
argue_with_a_tree
Feb 28, 2011 05:57 AM
Dan
Jul 26, 2006 09:28 AM
scc1983
Dec 15, 2005 04:35 PM
freeman
Aug 23, 2005 10:55 PM
