General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
LTD slip
Old Jan 26, 2006 | 05:21 PM
quontush's Avatar
quontush is an unknown quantity at this point
Default LTD slip
how do i know if i have a Ltd slip rear end?
Old Jan 26, 2006 | 05:58 PM
Default RE: LTD slip
You have to check your RPO code listings. My service parts identifier label containing the RPO codes is located on the inside of the door to my glove box.
I'll get the codes that specify the rear end setups in a bit here.
*EDIT* - Here they are for a 2000 and probably more
F46 Chassis: All Wheel Drive
GT4 Rear Axle: 3.73 Ratio
GT5 Rear Axle: 4.10 Ratio
GU4 Rear Axle: 3.08 Ratio
GU6 Rear Axle: 3.42 Ratio
G67 Level Control: Automatic, Air
G80 Rear Axle: Positraction, Limited Slip
The G80 should be the same for all.
Old Jan 26, 2006 | 06:31 PM
4lowlife's Avatar
Does GM put limited slip in the rear only? Or do some models have it in the front too.
second question. What is the size on the front ring gear? 5.25"?
Old Jan 26, 2006 | 07:24 PM
Hanr3's Avatar
Only the rear axle.
7.25" for the s-series.
Old Jan 26, 2006 | 07:35 PM
Ok, I think this information is accurate:
Front axle 7.25" ring gear 26 spline axle
Rear axle 7.625" ring gear 28 spline axle
I have found some conflicting information about the rear axle specs (some say it's an 8.5" 30 spline after '95...)
Old Jan 27, 2006 | 01:22 AM
quontush's Avatar
thanks
TOMSBLZR2014
Nov 19, 2014 03:33 PM
walkingtall
Nov 27, 2006 11:07 PM
Bauer318
Oct 17, 2006 01:32 AM
hdlogistics
Apr 10, 2006 03:03 PM
PhatKat
Mar 30, 2006 09:32 PM
