General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
Morning starting problem...
Old Nov 6, 2006 | 12:58 AM
88s10Blazer's Avatar
88s10Blazer is an unknown quantity at this point
Default Morning starting problem...
This has been going on for a while now, now that its getting cold. What happens is I go to start... CRANK CRANK CRANK CRANK CRANK, boom, stall, CRANK CRANK CRANK CRANK, boom, almost stall... gets going then. I didn't really think it was a big deal because it drives great, but snow is comming and its prolly just gonna get worse. It got a new dist. cap, plugs, wires, etc. when it was rebuilt. Any other suggestions? Also, it doesn't stall everytime on the first start up, but wants to. Thanks in advance.
Old Nov 6, 2006 | 03:48 AM
Chevy Lover's Avatar
Default RE: Morning starting problem...
Check the fuel pump pressure, coolant temp sensor and throttle position sensor
Old Nov 6, 2006 | 06:03 AM
magtec's Avatar
magtec is an unknown quantity at this point
my '88 with the 2.8 and 5-speed had similar starting problems when cold. the guy i gave the engine to when the truck was parted out said that replacing the fuel injector fixed the problem.
Old Nov 6, 2006 | 03:32 PM
MNHawk's Avatar
MNHawk is an unknown quantity at this point
Had a 3.1 Throttle body with simular issue.
Cleaned out the bowls and injectors (due to the second one seemed not to be spraying right)
And that fixed that.
But if I were you I would do that (if its TB) and check the TPS (throttle Possision Sensor) also
drillbit taylor
Feb 19, 2010 10:52 AM
atombob
22
Jan 3, 2010 12:09 PM
davidmd
Nov 26, 2006 12:47 AM
OCblazerowner
Engine & Internal
Aug 18, 2006 09:43 AM
chevylane2003
Engine & Internal
Nov 5, 2005 03:54 AM
