General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
Oxygen Sensors - What NOT to do...
Old Jan 4, 2006 | 02:36 PM
  #31
Default RE: Oxygen Sensors - What NOT to do...
Thanks.
You won't be disappointed with Mobil 1, plus, you can grab the 5qt container from any Walmart for $22 (Not Extended Life, just regular Mobil1 10w30 full syn.).
Old Feb 24, 2006 | 05:46 AM
  #32
Whittaker's Avatar
Whittaker is an unknown quantity at this point
ORIGINAL: swartlkk
I got a P0131 - B1S1 low voltage and P0134 - B1S1 Insufficient Activity... The low voltage means the sensor was running abnormally lean, and dumping fuel in like there's no tomorrow to try to compensate.
What does "Insufficient Activity" mean ? I got a P0134 at AutoZone. They could only say it was the oxygen sensor. Could a wire be off ?
Old Feb 24, 2006 | 08:08 AM
  #33
Insufficient activity means that the O2 sensor isn't switching from rich to lean fast enough in response to what the PCM is doing. The switch from rich to lean should happen very rapidly as the PCM adjusts the IPWs.
Old Feb 26, 2006 | 04:14 PM
  #34
Whittaker's Avatar
OK, so it needs replaced. Some questions then:
1) I see on the AutoZone website they offer an 'OXYGEN SENSOR SOCKET'. Does it require a special socket for removal ?
2) How many oxygen sensors are there, and I assume it/they are located AFTER the catalytic converter ?
3) Is it a one wire, two wire, or three wire ?
4)
ORIGINAL: swartlkk
Well, I have never EVER recommended that anyone buy anything but genuine AC Delco O2 Sensors when it comes to GM vehicles. Then I go cheap because I really didn't have the money to buy the AC Delco parts. $60 later (for 2 upstream sensors) and my Bravada was sittin pretty. I jumped 3 mpg and life was good.
That was until today. Driving to a fire training exercize and it starts to miss and stumble. Wide Open Throttle (WOT) is fine, but just cruising, it's missing quite a bit. Just before I pull into the fire hall parking lot, the CEL (check engine light) pops up. DAMN IT ALL!!! Anyway, I run the codes and get 2 B1S1 codes for the O2 sensor. Damn things were brand new Borg Warner not even 2 months ago (less than 400 miles on them) and one is bad already. Get this, only had a 30 day warranty... Now I would have spent double to get the AC Delco parts
Given that, I noticed next to the ARVIN brand of replacement oxygen sensors on the AutoZone website, that the "Warranty" is listed as a "LLT" (which they just told me over the phone is a LIFETIME WARRANTY, as long as you own the vehicle).
Given the price is the same or about $10 more (dependent on the number of wires), this sounds like a good deal, eh ?
'97 4.3LV6 4DR 4WD
Old Feb 26, 2006 | 04:52 PM
  #35
For any OBD2 blazer, you will have 3 O2 sensors. 2 pre-cat, one off the drivers side of the exhaust y-pipe, and the other right before the 'y' in the y-pipe on the passenger side. The 3rd is located behind the cat and is only there for catalyst monitoring, meaning the pcm does not use it to calculate the proper IPWs.
AC Delco AFS105 (PN: 25312200) O2 sensors cost me $75 each from my local AC Delco store. Nice thing about having a local AC Delco store is that they keep the dealerships honest with their costs. GMPD.com has good prices, but kill you with their shipping and handling - very rarely do you get your parts in a timely manner as well. The AFS105 is used in all 3 positions on the '96-'00 (possibly newer S-series Blazers).
These O2 sensors are 4 wire heated sensors so the AVRIN 'universal' sensors would not work. I would never recommend anyone get any of the 'universal' type O2 sensors. These sensors are highly sensitive to additional resistance in the wires. Even the connections made in the 'universal' sensors can cause premature problems. Plus, these sensors breath through the wires for their reference O2 content. If you were to cut off that flow of outside air, your sensor would fail.
Check with your local dealership for their price for the AFS105s. If you would like, I could purchase the AC Delco's from my local store and mail them to you directly (USPS priority + USPS padded envelope). I would have to see what those prices would be, but I wouldn't expect it to be more than $10 to send them.
My total cost for 2 AFS105s was $162.52 out the door. For the Bosch from Autozone, it would cost ~$115 (inc tax). I'd rather spend the extra $50 than have to worry about when they were going to give out on me again.
My parents are going through this with their '97 Caddy STS that has 4 O2 sensors 2 of which are a MAJOR pain. My dad had replaced them with Bosch sensors and 3 of the 4 went out just after the 3 month warranty ran out. They now have All AC Delco's in and the car is running MUCH better than it ever did with the Bosch according to my scans.
Old Feb 28, 2006 | 10:34 PM
  #36
Whittaker's Avatar
(I see this is also being discussed in another thread, but since the codes are different, I’ll keep it here)
ORIGINAL: swartlkk
OH.
So if I’m getting a P0134, how do I know which one it is ? Or should I get it read somewhere else ? The guy at AutoZone said it was not specific as to which one it was (this is when I thought there were only two), just that it mentioned the O2 sensor.
One of my local parts stores always sold Delco parts, I’ll have to check with them. Plus I should be able to get 20% off.
Bummer. A Lifetime Warranty would have been nice.
Old Feb 28, 2006 | 10:45 PM
  #37
P0134 - HO2S Circuit Insufficient Activity Bank 1 Sensor 1
Refer to the attached image to see where B1S1 is located.
[IMG]local://upfiles/667/A6724BB1537C4D9B9B4626871F30C451.gif[/IMG]
Old Mar 1, 2006 | 12:12 PM
  #38
DaveLance's Avatar
DaveLance is an unknown quantity at this point
As an FYI, my '96 (OBD2) has 4 O2 sensors. One from either side of the engine, one pre-cat and one post-cat.
Old Mar 1, 2006 | 02:19 PM
  #39
Whittaker's Avatar
I think the change was part way through the '96 model year.
Old Mar 1, 2006 | 02:28 PM
  #40
Whittaker's Avatar
ORIGINAL: swartlkk
THANKS !
I saw the pic in the other thread, but I didn't know which sensor was indicated by that code.
