General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
Pitman arm replacement
Old Jun 11, 2006 | 05:37 PM
frankjc's Avatar
frankjc is an unknown quantity at this point
Default Pitman arm replacement
Anyone got a step by step pitman arm replacement article? I need to replace mine, any help would be appreciated. Thanks. Frank.
Old Jun 11, 2006 | 05:46 PM
Default RE: Pitman arm replacement
My references state to remove the steering box from the vehicle, but I do not think that is absolutely necessary. You will need a pitman arm puller and probably a tie rod fork. Use the tie rod fork to pop the connection between the pitman arm and the steering linkage. Remove the retaining nut on the bottom of the pitman arm to steering box shaft. Then use the pitman arm puller to remove the pitman arm from the steering box.
What problems are you experiencing?
Old Jun 11, 2006 | 10:54 PM
frankjc's Avatar
Just some loosness. Everything else was replaced. Someone was supposed to replace it for me as a favor, but it never ended up happening. He didn't have time when he replaced the other parts. I am sure I can do it myself, with a few tips.
Thanks.
greatwhite
Nov 28, 2010 11:54 PM
88s10Blazer
Dec 24, 2009 08:43 PM
GMdesigner
Aug 23, 2007 04:57 PM
kornphlake
Dec 18, 2006 02:18 AM
RedOctober
Oct 11, 2006 09:00 PM
