General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
Problems with 1991 S10 Blazer
Old Oct 7, 2006 | 12:17 AM
sampsond135's Avatar
sampsond135 is an unknown quantity at this point
Default RE: Problems with 1991 S10 Blazer
I'm not sure if I'm going to keep her or not. Started having problems again tonight. I don't get it. Runs fine for two days and ~100 miles, then starts choking out again. I'm dropping her off at a local garage Sunday night. I'm sure it will be the same old story. I'll keep you posted.
[IMG]local://upfiles/3890/0963EDD7FFF445E7BF081729060A8132.jpg[/IMG]
Old Oct 7, 2006 | 12:53 AM
USMaverick101's Avatar
USMaverick101 is an unknown quantity at this point
Can i have ur tires if u dont keep here [8D]
haha
Old Oct 7, 2006 | 09:38 AM
DetroitMuscle's Avatar
DetroitMuscle is an unknown quantity at this point
Seafoam is best thru the brake booster line, or PCV line, let the engine do the work once 2/3rd to 3/4's is gone put the rest in the gas tank.
Check your vacuum lines, especially if you dont have a POSILOK on it. That was the number 1 cure for the ailments of the blazer, i did the motor 7/32's and 5/32's line now I need to figure out how to bypass the 4x4 vacuum system.
Where is this blazer located? I might be interested if the price is right and its close enough.
Old Oct 7, 2006 | 11:24 AM
Blazer is in Salem, Indiana. About 40 minutes north of Louisville (KY), about 90 minutes south of Indianapolis. I haven't considered a price.
Do you replace vaccum lines because of leaks, or because they are clogged? I can't find any lines that leak. Not sure if any are clogged. Where are the 7/32 and 5/32 lines located? Least I can do is pull them off and make sure they are flowing well.
Grizzle21309
15
Jan 28, 2013 10:42 AM
ct12
Jan 8, 2011 03:49 PM
tim_dean
Jan 8, 2008 03:16 AM
impala73
Jul 9, 2007 03:56 PM
f2fire
Jan 5, 2007 12:19 AM
